I am trying to install a new Honeywell Model RTH5100B digital thermostat to replace my Dometics analog thermostat. I am pulling out what hair I have left. I have the following wires- red,orange, black...
On the older Dometic analog, remember that for high fan, you must hook up both high and low (orange and blue in the above pic). The leads switch grounds for the relays in the upper boards.
FWIW- They use 2 relays for the fan- the low fan wire hooks to an on-off relay, the high fan wire hooks to a high-low relay. This way it is impossible to energize both speed windings.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
