rbp111ExplorerMay 20, 2017I need helpFirst of all, I have a 50 amp fifth wheel and so obviously I have had a 50 amp power supply for several years. I also have a 50 amp surge protector/Electrical Management Systemm(EMS), which is used b...Show More
wa8yxmExplorer IIIMay 20, 2017It is possible the problem is in the Energy Monitor/Surge Guard. disconnected or broken wire plug side.It is also possible it's in the wiring You need to test the outletUsing great care and a volt meter you should have 240 volts side to side120 side top and 120 side to bottom No matter which side.Another suspect is the plug itself. What color is the Roundish pin, Bright shiny copper. Black with tarnish.Copper tarnish is non-conductive.. Unlike gold oxide.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
