First of all, I have a 50 amp fifth wheel and so obviously I have had a 50 amp power supply for several years. I also have a 50 amp surge protector/Electrical Management Systemm(EMS), which is used b...
Thank you BFL. You said it accurately. I did plug in directly to the outlet box and tried to find out if the circuit tester would show the open ground also. (It did not) I turned off the electricity after doing the check. I call an electrician tomorrow to fix or replace the box.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
