Lynnmor
Jul 02, 2018Explorer II
dougrainer wrote:
I STILL ASK WHERE IT SHOULD BE LOCATED PER THE INSTRUCTIONS IN AN RV? I AM an expert as it relates to RV's. There are literally MILLIONS of these installed in RV's for the past 20 years. Very few time have I ever seen damage and the damage I found was due to the valve freezing and then the RV'er did not realize he was pumping water into the bath area. Like I stated, just use the Brass replacement. They never leak. And some, are installed thru a floor cut out where IF they leak, it dribbles down to the water bay compartment so you can see it is leaking. THEY ARE NOT A BOOGEYMAN THAT YOU MUST FEAR!!! But, of course, some of you seem to be frightened by them:B I would have no problem having one in my RV. I don't sweat the SMALL STUFF, like some of you:B Doug
I do my own work, but if I were to hire someone, they **** well better sweat the small stuff. Since the stupid, cheap things do leak, place them in a hatch that drains outside or design a hose inlet that incorporates a vacuum break that is external. Junk is junk, sorry that some can't see it when presented to them repeatedly.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
