azrving
Sep 10, 2014Explorer
pianotuna wrote:
Hi rjxj,
That's why I keep going on about temperature compensated charging. My Magnum has it and today it was doing 14.9 volts and 2 to 4 amps in Absorb.rjxj wrote:
After our first winter of travel last year and finding out how poorly converters work I started to look at solar then came to the part of an old guy climbing upon the roof over and over or lugging the panels out and setting them up. I backed up and left it alone and decided to make a gen and real battery charger work.
Sorry I said winter. My bad.I should have said seasonal travels as we are trying to stay were it is as warm as possible. My low would probably be about 45 and high of maybe 70. I do understand and agree with you as to the benefits of temp comp. I will keep it in mind if I go to solar.
At the time my basic problem was low charge voltage with an old converter and trying to do it on a loud gen. Bad combination.
Now I have a quiet gen and a 15.3 v battery charger and have done full charges in 4 hours.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
