Artum Snowbird wrote:
I would start with two 3/4 inch thick pieces of pretty plywood that fit fairly tightly from front to back and top to bottom on each side of the box. Finding some solid wood to screw into from outside your plywood would be nice. Next, you again tightly fit a 2 by 12 across between the plywood pieces. Once you know the right height and depth for the 2 by 12, box in the back and bottom with some 1" by 1" to hold in the 2X12. Screw and glue the holding pieces into the plywood on each side. After that, put in the 2X12 and then screw pieces on the front of the 2 by 12.
Now you have a solid mounted heavy duty piece of wood to bolt on your TV Mount. Cover up the mounting boards with thin decorative matching trim and it will look great.
Did something very similar in our Titanium 5er and it worked very well. If not travelling maybe you don't need 12" wide material.
