DiskDoctr
Sep 17, 2013Explorer
westend wrote:
FYI, 6v golf cart batteries have the same footprint as a grp. 24, the height is the difference. If you have a single battery box, either add another or buy a double box. IMO, having only a single grp 24 is always going to be a problem. There are going to be those times when it gets really cold and you want the furnace running or there is some need for extended light after dark. By using the available capacity right to the threshold of 50% SOC use or beyond is just a formula for battery replacement.
For me, I dislike moving batteries around. There is nothing heavier I can think of in my rig that would be movable. IIRC, the batteries even out weigh the wheels.
A group 27 or even a 31 would be a MAJOR help. Make sure it is a TRUE deep cycle, not a 'marine' or combination battery. A 31 is slightly larger than a 24, but I've found it to fit (tightly) in most battery boxes. If not, the 27 should fit.
Group 31 is 30%-50% more capacity than Group 24. Golf cart batteries are even more.
Here's a good read. Notice the chart comparing battery types and capacities.
http://www.solar-electric.com/deep-cycle-battery-faq.html
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
