RDMueller's avatar
RDMueller
Ideas to extend stay when dry camping/no generator
I've read many threads here on the topic and have learned a lot, but so far haven't found anything that totally works in my situation. We have a small pop up with a single group 24 battery. The good news is that our electrical needs are pretty minimal, a few lights, the water pump and depending on the weather, the furnace for at most a few hours a day. I figure we normally don't exceed 20 Ah per day.
There's a campground we enjoy that doesn't allow generators. The sites are very shady so solar wouldn't really help much. We've been ok for 2 nights, but any more than that won't work without a way to charge the battery. More/larger batteries would help but there just isn't room on our pup, plus we would still be limited in how long we could stay. What I would like is a reasonable way to charge the battery while I'm there. Since we always do at least an hour of driving around on any given day, using the truck's alternator seems like a perfect solution.
Here's what I'm thinking - put a deep cycle/house battery in the truck connected to the alternator just like is done with motorhomes. This battery would be more or less fully charged each day from driving around. Then I would have 3 possible ways to use the power from the truck's house battery:
First I could connect the truck's house battery to the pop up's battery using jumper cables each evening. Although this method would never fully charge the pop up battery, power should certainly flow from the fully charged battery to the somewhat discharged battery until they equalize.
The second option would be to connect an inverter to the truck's house battery and then plug the pop up's 120v shore power cord into the inverter, thereby charging the pop up's battery via the converter.
Finally, I could just swap the two batteries once each day. Although this would be more of a hassle, it would result in the pop up getting a freshly charged battery once each day.
I'm interested in hearing the advantages/disadvantages of each of the above plans. I was thinking about actually trying each one out, but I'm betting that there are other RV'ers out there that have already tried these (and maybe other ideas as well). Any advice or suggestions would be really appreciated!
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
