DougE's avatar
DougE
Identifying Electric Short?
This is on a 2015 GMC Canyon but is really a generic question. There is a plate with non-replaceable fuses on top of the battery (see photo below). I would suspect this unit is quite expensive and only available from GM in the near future. If one of these fuses pops the entire assembly would be replaced although I think I could modify it for replaceable fuses by cutting off the existing fuses and drilling a few holes. After supposedly identifying a short on a normal fused circuit I would typically just stick in a low amp spade fuse and see if it pops. At the anticipated cost of this assembly, however, I really need to use a non-destructive method. What approach would you electric guru's suggest?
  • Somewhat, red31.
    300a - Starter
    250a - Underhood fuse block
    100a - Instrument Panel Fuse Block
    100a - Cooling Fan Control Module
    100a - Power Steering Control Module
    See why I'm concerned?
    So do you currently have a short or this is just a what if? I would imagine that the fuses are protecting a fuse box down the line. So if something shorted it would blow the 20amp fuse before it would get to the 100amp main.
  • It's a "what if" due to the unusual nature of this rig. It seems to be too new for any forum action (anywhere) yet. I don't want to be out in the boonies and then try to figure this out. Apparently no knowledge has been developed for this rig yet. Believe me, I've hunted.
  • You could make a "catastrophic" replacement easy enough, something you could just bolt in place if you lose any functionality in the boonies. All you need is a piece (or two) of copper bar, a short battery cable, and the same size fuses.
    Heck, this isn't that frightening, my BMW has an explosive charge on the positive cable. If the vehicle is in a bad accident, the charge detonates but leaves power to the lights and some other accessories. It shuts off power to everything else.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
