82tpsmith's avatar
82tpsmith
I'm at a loss and need help :(
Well I've have tried almost everything. My refrigerator quick cooling about a week ago. I'm living in whitefish, MT and the temps got down to -18 degrees one night and were at -5 to -10 for several nights. I've got the trailer all ready for winter, except I didn't insulate the fridge. Sooo...
I've looked on all the forums, done lot of research online and still can't get it to start cooling again. Here's what I've done so far.
After I noticed the fridge was not cooling, I put a 150W clear bulb back there to try and generate some heat. Waited a day nothing. Then I got some of the reflect-ix bubble insulation stuff and covered 2 of the 3 vents on the lower access doors to the refrigerator. Waited a couple of days, nothing. I've tried running on gas for a day and back to electric, nothing. Then decided since it was still cold outside I would pull the fridge out and try to warm it up. So I pulled the fridge out and had it sitting in our living room for 2 days with a heater aimed at the back side to warm up all the coils and totally thaw anything that might be frozen out. Put it back in today around 11 and have not seen a temperature drop in the inside of the fridge. It has been about 3 hours. I would have thought that I would see temps go down at least 5 or 10 degrees but thermometer still says 62. I just don't know where els to go here.
We bough our fifth wheel new and it is about 3 years old. Never had any other problems with the fridge in the three years we've had it.
Would love some ideas what might still be wrong, or what else I might do.
Thank you so much
  • You might ask the moderator to move this to the Tech Issues forum. One of our members, who is a well known RV tech and has his own RV repair business, frequents that forum and may join in on your thread with advice.
    Barney
  • Unplug thermistor cable from lower board and force cool it.
    Also get some air flow thru that lower vent....air flow has to move across back of fridge from lower vent thru upper vent
  • I do not know much about
    reefer's but i would take it out and turn it upside down and keep it warm for several hours then put it in and it will work again.Same thing happened to me and i did just that and it worked 3 yrs.and was working when i sold the motor home. I read how from a repair manual from C.W.It is worth a try they suggest letting it stay upside down for 12 hrs.I certainly hope this helps replacement is expensive.
  • well I take back anything sarcastic I might have said about turning it up side down. We had put the fridge back yesterday and was still not working. I though what the heck I've tried everything else, lets turn it upside down. So this morning I took out the refrigerator, again, and turned it on it's side. Let it sit for a couple of hours. then turned it upside down, waited a couple of hours, and then flipped it from side to upside down to side again. You could hear all the liquids moving around as I did this.
    Put the fridge back in about 2-3 hours ago and I'll be darned if it ain't 11 degrees in the freezer now. The refrigerator still is comming down in temperature, but I do believe that fixed it.
    I would have never though of doing this. Can't imagine what I did, but I am sure glad it seems to be working.
    Thank you all SOOOO much for the help, and I'll post back tomorrow to update the temps after 24 hours or so.
  • It is called 'burping' the fridge. Common thing to need to do back in the days of 3 way fridges.
  • You know the 'first' fellow to report flipping the fridge probably involved WARM beer, a couple of buddies, and a big hill, then a 'better put it back in the camper before the wife sees what I've done! :D
    Next thing you know, wife says, "Guess what? We have ice cubes!"
    ...and a 'Redneck Repair Procedure' is born! LOL.
    But seriously, it is a fairly well respected fix. If it works, you're golden. If not, you haven't lost anything.
    Glad you are back and working again.
  • Well just another quick update. Been several days and we still have real cold temps in the fridge. My neighbor had the same problem, and we even went over and flipped his fridge. Thanks for all the help everyone!!!
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
