BTPO1
Nov 18, 2014Explorer
donn0128 wrote:
You mentioned moving the thermostat around and it finally worked? Take the thermostat apart and jumper the two heat wores together. I suspect you might simply have a bad thermostat
X2, This has happened in my S&B withe digital thermostat, it turned out to be a bad connection on the thermostat. Sometimes the contacts in a thermostat just get dirty and need to be cleaned. JMO
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
