Harvard
Nov 18, 2014Explorer
QUOTE: "I forgot to turn the thermostat off before going out in search of a space heater, came back about 4 hours later and the furnace was finally working.
It worked perfectly for about 5 hours (I didn't even have to turn the thermostat on and off a million times to get it to work when the temp. fell).
This morning (when it was 4 degrees, as luck would have it) it reverted back to what it was doing before (blower runs, no ignition)." END QUOTE
There is a remote possibility of an oil trap in the copper line to the furnace which may pass gas when warm (low viscosity) but not when cold (high viscosity). If convenient do a bubble check for gas pressure at the furnace gas connection if and when you are going to disconnect same.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
