doxiemom11
Nov 18, 2014Explorer II
Is it possible to run an extension cord( a heavier duty one) outside and plug it into a 110 plug on your power pole for 1 of the heaters and plug the other inside the coach? We are a 50 amp rig running on 30 amp and by having one plugged in the living room area and the other in the bedroom, with both set at medium heat setting, we can run both at one time. We do have to shut one off if we want to make coffee, use the microwave , the toaster or something like that.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
