Harvard's avatar
Harvard
Impact Guns and Extensions Do Not Mix
I am sure this is old hat to most but it is something I learned last week after 71 years of not knowing. I tried to remove wheel nuts using an 1/2" air impact gun with a 6" extension. It just sat there and hammered without coming loose. As soon as I got rid of the extension the problem went away. Now I think I know how a torsion bar works. :S
  • smkettner wrote:
    Was it an impact rated extension? Otherwise yes direct always works better.
    No, it was a standard hand tool extension with a removable socket. It just did not occur to me until I was not getting the expected results.
  • Was it an impact rated extension? Otherwise yes direct always works better.
  • j-d's avatar
    j-d
    Explorer II
    That IS correct. Extension, and the extra joint (extension to socket) soak up some of the impact's torque. Seen "Torque Sticks?" it's an extension with a built-in socket that will actually limit what the impact can deliver to the nut.
    I found that even with an (impact) extension, my 7/8" impact socket had trouble with the rear wheels. I used the extension because of interference with the axle hub. Harbor Fright sells individual deep impact sockets but apparently 7/8" (23mm) isn't popular enough to sell separately, just as part of a set.
    Back to it... Torque Sticks
    Color Coded for Hex Size and for Torque.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
