otrfun
Jul 22, 2013Explorer II
beemerphile1 wrote:
Unfortunately having both grilles in the side wall is less efficient than one on top. The object of baffles is to get the air flow through the coils and not around them. Venturi effect is not in play here.
Here is a good tutorial on correct and incorrect refrigerator installations;
http://www.rvmobile.com/tech/trouble/vent.htm
If you're referring to the upper louver area (just above the heavily finned condenser coils) yes, I agree the venturi effect is minimal here. However, ref the coils located next to the flue and baffle board, the venturi effect is very much in play here. I will admit the it's overall effectiveness may be somewhat restricted when the moving hot air attempts its final exit through the upper louver area (vs. a vertical roof exit), but IMO it's still in play.
Not sure if it's a temporary issue, but your link didn't work this morning (also tried www.rvmobile.com).
