beemerphile1
Jul 22, 2013Explorer
The Venturi effect is the reduction in fluid pressure that results when a fluid flows through a constricted section of pipe.
http://en.wikipedia.org/wiki/Venturi_effect
Convective heat transfer, often referred to simply as convection, is the transfer of heat from one place to another by the movement of fluids.
https://en.wikipedia.org/wiki/Convective_heat_transfer
In both of the descriptions above, the fluid can be air.
