chainegang
Feb 21, 2018Explorer
You can rent a kerosene heater from most national hardware stores. They are sometimes called bullet heaters and are used extensively by contractors for outdoor situations. Needs to be plugged in to operate but takes very litlle electricity. The blast from the heater will flood the area of the frozen tank and should reduce or eliminate the issue. Good Luck.
Buy the way you can own a homeowner version of the heater for around $150.00. Home depot, True value, Lowes to name a few.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
