time2roll
Feb 21, 2018Nomad
30F? is that at sunrise or at 2pm?
You mentioned backflush did not work well... seems like you may have a solid object in the tank. If it really is ice it should clear for doing the back flush a few times. May need a plumber with a camera to scope this out. Maybe Harbor Freight has a low cost camera to buy.
Do you rely on the tank sensors to know the tank is empty? Very common to have a false reading.
I doubt tank and pipe is frozen solid but here is a heat pad you can order: www.ultraheat.com
May need someone there with experience to actually look at it. Mobile RV tech should be able to set you on the right path in 30 minutes or less.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
