ndrorder
Feb 22, 2018Explorer
The drop light will only be effective if you have an incandescent bulb. 75W is still a lot of heat and enough at 30ish degrees. Did you see the clamp lights?
https://www.homedepot.com/p/HDX-150-Watt-8-5-in-Clamp-Light-with-6-ft-Cord-64855301/303870163
I was more thinking a hole in the slinky.
Wishing you luck.
Cliff
Wishing you luck.
Cliff
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
