joraz's avatar
joraz
Inaccurate VMS Data
Cummins M11
On our last rig the VMS data was right on. On this one, Three readouts apparently are wrong.
MPH: When running at 60 mph on the dash speedometer, two GPS units (Tom Tom & phone) agree that we are traveling at 60. The VMS shows 62. The only thing I can think of is tires. We are running the right size (275/80) Continentals. I know I can add a 3% multiplier to the VMS to compensate and that would fix the readout but I'm curious as to why it would be off. Continentals slightly smaller?
ODOMETER: The dash (mechanical) shows 103,228; the VMS shows 108,031. Almost a 5% difference.
ENGINE HOURS: Way off. The gauge in the back shows 1,325 hours and the VMS, 2,193. I haven't checked the back gauge to see if it's working but it may not be as those hours would yield a 78 mph average. This engine is no dog but that's sounds pretty darn optimistic!
Just looking for ideas. Thanks.
jor
  • Thanks. I don't think there is a parameter for tire size and the tires are the correct size for the rig. I have already input what they call a multiplier in the odometer field. (.9556). That corrects the odometer reading. Next time I fire it up I'll check and see if the speedometer reading reflects the change. I had Michelins on my last rig which was very similar to my present one and the readings were right on. I'm thinking the Continentals are just a hair shorter.
    jor
  • The VMS needs to be reset with correct tire size or the percentage changed.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
