Harvard
Dec 04, 2013Explorer
This is a mute point but I believe the RV (isolated from ground by rubber tires) is a capacitative plate located between the high tension lines and ground. This conductive plate (RV frame) becomes a voltage divider between the high tension wires and ground. Fortunately the tires have a much higher dielectric value then does the air (between the RV and the high tension wires) thus the 15 VAC RV to ground is not excessive, troublesome but not excessive.
What I am implying is that the measured VAC is not an "induced" voltage but a capacitatively charged voltage on the RV chassis. It is the same phenomenon you see with a length of ISOLATED ground conductor sheathed/bundled together with the same length of 120 VAC Hot Wire and a 0 VAC Neutral wire.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
