LScamper
Dec 04, 2013Explorer
Harvard is perfectly correct.
This is a capacitive voltage divider. The capacitor between the power lines and the RV is small compared to the capacitor between the RV and ground. Thus a large voltage between the lines and the RV and a small voltage between the RV and ground. This would hold true even if the lines were DC instead of AC.
The current drawn when you ground the RV would be small because the capacitance is small and the reactance is high.
This was discussed a few times and I made the same case for a capacitive divider. But no one agreed with me, I don’t expect them to this time!
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
