SJ-Chris wrote:
How about this charge controller?
https://www.amazon.com/gp/aw/d/B089SH3W85/ref=sspa_mw_detail_6?ie=UTF8&psc=1&pd_rd_i=B089SH3W85p13NParams#aw-udpv3-customer-reviews_feature_div
$49.90 with free shipping
60a PWM
12/24/36v battery system
States up to 720w if using a 12v system.
Maximum input voltage from the panel: 92v according to the seller.
If these specs are true, then it seems like you could buy two 250w panels for $50x2= $100 and this charge controller ($50) and all the misc other items (~$60) and have a 500w solar system for ~$210.
Note: This requires picking up the panels as shipping makes them too pricy.  (I happen to be visiting near where their business is located in Arizona right now.... :-)
What am I missing here?  Thoughts?
Chris
To be very clear.
PWM controller while it CAN take a higher voltage in, it WILL need a HIGHER VOLTAGE BATTERY BANK to work correctly.
In other words, PWM 30V panel = 24V battery bank voltage.
It PWM WILL NOT WORK with 30V panel to 12V battery bank.
NO PWM controller have any means to decrease the 30V output of the panel to a usable 12V charging voltage.
To use ANY 30V panel with a 12V battery bank you NEED to go with MPPT.
IF you do not want to buy MPPT but want to buy and use a 30V panel voltage then you MUST convert to 24V battery bank.. But then you now have the rub of all of those 12V appliances, right?
Well then you will NOW have to spend more money on a DC-DC converter to bring the 24V battery bank voltage down to a usable 12V..
More money, more things to go wrong, burn up, smoke and now you have a very non-conforming, non-standard "one off" system that most places will never want to touch if it goes badly wrong.
Go that route, you better read up on it and understand everything 100% and you better buy some spare critical parts since you will not be pulling into a Walmart to find parts for it.
If you WANT those low cost $50 30V panels, BUY THE MPPT CONTROLLER, just realize your "bargain" is not longer as much of a bargain because you MUST spend more for the controller ($100-$200) or configure a 24V battery bank and HIGH POWER DC-DC converter ($$$$).
Example a no name 60A 24V to 12V buck converter can cost $120
HERE..
But wait, theres more..
With a lot of buck converters you can run into issues, they tend to not be "isolated" output which now you must pay close attention to whether it is regulating the negative ground or is is regulating the positive voltage..
And not to mention that is only 60A and your batteries CAN supply a lot more than that..
For more insult to injury, if you want a inverter to make some 120V, well that 60A converter isn't going to cut it if you have more than 500W-600W non inductive load.. Yep, you now will have to spend more money on a 24V input inverter..
Be cheap if you wish, that is your prerogative, but personally, SKIP those $50 24V panels if you do not want to spend money on the MPPT controller.
