If you are a salesman, percentages are a lot of fun.
when we did all this about eight years ago, using a 130w panel all day, it came out that around 8am you got 2.5 amp with PWM and 3 amps with MPPT.
So, 20% better with MPPT---wow!!!!
By high noon, it was more like 8 amps with PWM and 8.4 amps with MPPT for a percentage gain of 5%
that was where the battery voltage was held fairly constant by running a load on it so it would not get charged up. Why that? Because with MPPT, amps to the battery are output watts from the controller/ battery voltage.
So during the day, the battery voltage climbs so ever reducing percentage of amps to the battery for the same output watts. But output watts are also highest at high noon and lower in the shoulder hours.
You might still have a day where the overcast clears at noon and you are starting with best solar on a low battery. Say that is the case.
130w/12.2 = 10.6 amps , but then after an hour, with the solar strength still good, battery might be at 13.2, so
130/13.2 = 9.8 amps
So everything is in motion and as a salesman ("drummer") you can pick any percentage gain you want and not be actually fibbing--leave the scenario to the "small print"
Heck, at 6:30 am you might have 1 amp on the PWM and 2 amps on the MPPT and then be able to claim a 100% gain over PWM! Wow! But it is only 1 amp more (don't mention that!).
You do usually get a little more with MPPT. If it gets your batteries full by 2 pm instead by 3 pm with PWM is that worth anything? Depends!
