pianotuna wrote:
Gde,
The company sells a 250 watt with 20 amp mppt controller for $165. Considering my system was $1700.00 in 2005 it is a heck of a deal.
They also have some larger 50 amp mppt controllers sold in a kit for a few dollars more. That is what I'd advise, as they can add some panels that way.
Goodness knows whether the controller or panels are great, poor, or bad.
Sadly, with pretty much anything electronic, you cannot "compare" cost of something that was "cutting edge" 15 yrs ago.
Cost of panels back then was well above $5 per watt and MPPT was pretty much in its "infant" stage of life.
Like I have mentioned, you can buy two new "12V" 100W panels and even get a 30A PWM charge controller for $200 now days..
Kind of takes the starch out of the savings that one lonely $50 24V 250W panel is going to cost once you buy the proper MPPT controller which you mentioned from the same vendor is $165..
From my math, that used panel setup is $215 (with your MPPT price quote) and that doesn't include shipping.. And you still have a used panel, while they do have relatively long life, it won't be as good as a new one starts out or the used panel may have a few dud cells rendering it with less voltage and capacity..
Not to mention a 250W panel is huge and may pose difficulties on some RVs with other things on the roof..
MPPT does not always "equal" "more power" or "longer charging" either, there are limitations on how much energy the panel can actually efficiently garner from the given strength and duration of the sun that falls on it. MPPT attempts to maximize what can be harvested but in many cases you will only be talking in fractions of Ahrs per day over a PWM controller with a single 24V panel. Not uncommon for home panel arrays to be wired for 48V and higher..
You roll the dice and take your chances, but to me this panel is really more suited for folks setting up a 24V or higher battery system which opens a whole nuther can-o-worms..
In other words, you would have to REALLY "want" these panels to go through the trouble of making incompatible voltages work together.
