Bobbo wrote:
A bonding plug on the Honda generator will fix that right up. About $2 in parts at any big box hardware store.
Buy a 3 prong plug and about 2 inches of wire. Open the plug and wire the NEUTRAL and GROUND pins together. DO NOT HOOK ANYTHING TO THE HOT PIN. Plug that into an outlet on the generator, and the floating NEUTRAL problem with Progressive units is fixed.
You don't have to run the risk of bypassing any of the Progressive unit's safety tests by using the bypass switch.
I have done that using one 2000i. Now if I parallel two 2000i's together do I need a bonding plug for each generator?
