MEXICOWANDERER wrote:
Still inquiring...
Has anyone here opened up ANY voltage correction device for RV use and determined what is inside for transient voltage suppression? That wonderful pair of companies, refuse to divulge information because of National Security reasons.
Why is it I think they contain a dollar's worth of MOV's and nothing else?
There are two kinds of "Surge Guards" One, is very close to exactly what you describe (Perhaps 5.00 worth of MOVs a couple LED's and a few resistors). I seriously DO NOT recommend this type of device,, They are not true surge guards, they are spike suppressors.
That said. They have value, I have one (several in fact) These are also sold as power strips (The computer is plugged into one right now).
But as the primary protection device,, Junk
Now Progressive Industries makes some like the HW50C and PT50C (they also make a 30 amp version of both)
These have an LCD display that shows you error codes, voltages, and currents, they monitor current (Mostly because thy can, do not act on it, just monitor it) and volts If the voltage goes over/under pre-set limtes or if the frequency goes outside a pre-set range they shut you off
Why do thaey do that?
Many RV parks (older ones) have rather anemic wiring, they were layed out when RV's mostly used 15/20 amps, and some used 30 and nobody even thought of 50's.. So the underground wires are way too small, This means when the park is empty power is good,, but as the park fills 120 becomes 115 becomes 110 becomes... Well I've seen 84 at the pedestal.
This low a voltage can cause your Air Conditoner compressor to overheat and let all the magic smoke out of it.. NOT a good thing. Not a good thing at all.
And in some cases the park management will have the power company tap a bit higher on the power transformer, Now when the park is full you get say 112 volt, but as it empties out that goes up, long around 130 to 135 your protector will shut you off because beyond that power supplies in televisions, radios, microwaves, sat receivers and such (This includes some converters) also release their magic smoke.
And, then there is the poor guy who plugged into what he thought was a TT-30 (Heck, it may have actually BEEN a TT-30 he had proessionally installed by someone who did not understand the words MAX 125VAC printed on the thing
The LCD models will say 240 volts
And if you are smart and have read the fine manual you will know that means UNPLUG NOW and try a different outlet.
But the non-lcd models will let double voltage hit your rig and .... Let the smoke out.
