stacaz822
Nov 17, 2018Explorer
For that many amps coming from the solar panels, you will need at least 4 gauge wire or larger, or you will be losing a lot of power due to heat dissipation. Make sure the solar charger has a four-stage "smart" converter to charge the batteries. If you only have 2 12V AGMs, then a couple hundred watts is certainly enough, unless you run your TV and heater all night...and all day...
