Gdetrailer
May 18, 2013Explorer III
Salvo wrote:
The knob you would want to twist controls output current. That type of control doesn't exist on your dc/dc converter. Short of a total converter redesign, it's impossible to obtain maximum power point control.
SalHiTech wrote:
The closed loop control is a human twisting a knob until watts are max, by reading a watt meter. Repeat as necessary.
Jim
Sal..
Not true.
By being able to increase the output VOLTAGE to the batteries you ARE increasing the current which actually increases the wattage.
The issues that my happen with this setup is not having enough solar input to support the circuit (IE draw too much current from panel and the panel voltage drops below the min input voltage of the circuit).
Or forgetting to manually reduce the output voltage when not being used (IE storage) and boiling the batteries into the grave.
Or the actual "gain" in wattage is overall way to small to worry about.
Personally it is nice to see someone here thinking outside the RV box for once.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
