RoyF's avatar
RoyF
Insect screen over furnace exterior vent can save big money
Just paid a big bill to have dirt dauber nests removed from RV furnace. Dealer said furnace was heating at only about 50% due to reduced air intake. Wasps got in at furnace exterior vent.
Installed inexpensive insect screen over furnace exterior vent to keep little buggers out in the future. I've still got things to learn about RVing. Wish someone had told me the story about dirt daubers and furnaces.
  • Remove them because they get hot when the furnace is on. It's a COYA for the screen manufacturers so they won't get sued if someone burns themselves on one.
    Do I remove mine? No!
  • down home wrote:
    I've held off putting screens in or on because of cautions from mfg.
    However one of the furnaces, fan was making a racket. It had a mud dauber nest on it.
    Wouldn't hurt to have them on the furnaces, in summer. Pull them off when cold so no ice forms on them.
    Maybe some kind ,of stick on base, for when you are parked and not using the RV.
    They're held on with little springs so it's easy to take them back off when ever you want and it will leave no marks.
  • I've held off putting screens in or on because of cautions from mfg.
  • Old-Biscuit wrote:
    NOPE......
    The air flow balance is so close/critical to proper combustion that the intake/exhaust are wide open with NO restrictions.
    Due to that....neither mfg. recommends the screens be installed.
    I don't think so.
    I've used screens on my last two 5th wheels on the fridge and water heater vents. And the aftermarket hemispherical screens on the furnace intake. No mud dauber nests and no issues with anything not working properly. YMMV.
  • Of the rigs I've owned, the heater manufacturer's manuals always said not to use them but never do they explain why. Probably because they would cost something.
    For that reason I have been using the aftermarket screens on every RV I'v owned over the last 30+ years and have NEVER had any problem what so ever.
  • Some of those aftermarket screens come with a warning to remove before operating the appliance. Mind did.
  • NOPE......
    Just make sure you routinely clean them aftermarket screens.
    Ever wonder why they aren't OEM?
    Just a guess:
    To save 3 cents? :)
  • Just make sure you routinely clean them aftermarket screens.
  • Here's a heads-up :
    They get into the water heater and fridge vents too.
    I posted threads recently on DIY screens for them.
    Good Luck, Mike
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
