Lynnmor
Aug 19, 2018Explorer II
I think that some don't know how to properly adjust wheel bearing CLEARANCE. Here is the Dexter information: manual
If you operated a trailer with bearings so loose that the tires wore noticeably, you need to replace those bearings and the tires. If there was only the slight required looseness in the bearings, the tire is probably at fault.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
