CaLBaR's avatar
CaLBaR
Explorer II
Aug 18, 2018
Inside tire wear & bearing play in wheels Related or not?
Heading off to Montreal on Friday so brought the trailer home today to adjust brakes and noticed some strange tire wear where the inside of the tires are wearing and some tread cupping. In 12 years of having this trailer never seen that before. Also found that a couple of the wheels have a lot of play in the bearings. Done my own bearings for years and never had that either.
Been about 1 1/2 years and about 6000 miles so now I have to do bearings tomorrow. Hope I don't find any issues and can just clean them, pack them and be done in an afternoon. Hope that is all that it is with the tire wear too.
Anything else I should look at while I am there. Plan to clean and lubricate the brakes too.
Thanks,
Rob
  • While your wheels are up in the air I'd give them a few revolutions to make sure you don't have the start of a ply separation. On our old Montana I had weird tire wear happening on the street-side, turned out to be a ply sep. The front tire was way worse than the rear, put on the spare. Luckily I made it back home without incident and bought new tires!
    A tip my dad gave me years ago when doing bearings was to tighten the castle nut, spin the wheel a few times and try and tighten some more. That would insure the bearings are seated properly and then back off the nut a tad.
    Dan
  • Thanks for the feedback corvettekent and MudChucker. That is what I thought as well. Hopefully when all is repacked I won't have this issue again.
    Can't figure out how the bearings got loose. Torqued the castle nut and backed off 1 notch so should have been fine. Guess I will see tomorrow when I pull them apart if the bearings are still fine or if something else happened.
  • corvettekent wrote:
    Yes a loose or bad bearing could cause inside tire wear. If you have to replace the bearings make sure that they are high quality bearing from the USA.
    100% agree.
    Consider that now you have the tire wear you may create a condition such that the wear will be amplified somewhat with the new bearings, consider rotating the tires, changing direction and balancing never hurt.
  • Yes a loose or bad bearing could cause inside tire wear. If you have to replace the bearings make sure that they are high quality bearing from the USA.
