tommygun714's avatar
tommygun714
Install New Charge Controller close to batteries
I am looking to install the New InetiPower 60Amp Charge Controller close to batteries as that is best for faster charging.
I am wondering about taking out old charge controller under stove. Can I just disconnect all wires and remove it? I was thinking that it is needed to power 12V system when we have hookups?
Then I wondering about how we charge batteries when hooked up to shore power, with relocated Charge Controller? Second Cord just to the Converter? Or how I might grab power that is part of the system when we are hooked up.
At the end of the day my goal is to:
1) Relocate Charge Controller location
2) be able to plug RV into Shore power and have batteries getting charged.
3) be able to plug RV main Plug into Champion Generator and have batteries getting charged.
4) Have New Charge Controller close to batter bank in front Storage (4 6v Trojans)
  • Boon Docker wrote:
    It seems like you are a bit confused.
    If you are replacing the converter (which it sounds like) it should go back in the same place the old one was or you are going to have a wiring nightmare.
    What he said x 2
  • Tommygun714
    From your profile, I get the impression that your 5er. is a 2018 model. What is wrong with the charger that is in it? :h
    If you want a new charger controller I would say just remove the one that's there and replace it in the same location. :S Get what you want but I would say inho, put it back where it's located. Least amount of work and wiring. :W
  • It seems like you are a bit confused.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 16, 2025
