Canadian_Rainbi
May 20, 2015Explorer
But where ever you put it, put it CLOSE to the batteries. The higher the charging current the closer you should be.
In our rig, due to poor placement of the controller and an awkward battery location, I have seen a full one volt drop between the voltage at the controller and the voltage at the battery at 20+ Amps. This fools the controller into tapering the charge waaaay too early.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
