barnaclepete1
May 20, 2015Explorer
vermilye wrote:2oldman wrote:I don't know about the design of the Prostar controllers, but many solar controllers are unhappy if the battery side is disconnected while the panels are still connected.barnaclepete1 wrote:It's ok, but not necessary.
ยท Is it ok to add a battery disconnect switch to the positive line in between the controller and battery for when I want to run a generator or connect to shore power (microwave or AC)?
Since you can charge the batteries with multiple sources, as oldman says, there is no reason to install a disconnect between the controller & batteries. A fuse would be a good idea...
Thank you. Good information.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
