wnjj
Sep 14, 2015Explorer II
What other wire colors are there and what other terminals are on the thermostat?
All the thermostat needs to do is send 12V down the white wire via a relay. Usually there's a power wire connected to to R or RH that provides the power to one terminal of the relay. If you temporarily touch the white wire directly to that it should start the furnace, bypassing the relay.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
