WyoTraveler
Sep 14, 2015Explorer
I didn't add or replace a themostat on my 2012 Jayco 19RD TT but when I had problems with my TT (It almost burned up about 4 months after buying it new) Jayco wouldn't cover under warranty but that is another story. I had a local dealer repair it. They pulled the A/C and furnace and bench tested everything. Then pulled out all the connecting wires and replaced them. The local dealer said it was the worst wiring job in a TT they had ever seen. Wire colors didn't match, no wire nuts, crimp connectors or tape on wire connections within the walls. A lot of those bad connections were found in the wall. I didn't have any more problems once the dealer replaced all of the bad wiring. I have no way of knowing if this was a one of a kind sloppy wiring job or SOP. As you can see I no longer own the 2012 Jayco 19RD TT.
If the replaced thermostat isn't working you may want to trace out all of the wiring.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
