Chris_Bryant
Sep 17, 2015Explorer II
If you have 12 volts (nominal, of course) at RH, then W should have 12 volts when calling for heat. Make sure W is connected to the "cold" thermostat lead from the furnace. Try setting heat to electric, rather than gas. (or vice versa).
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
