Iraqvet05's avatar
Iraqvet05
Installed Honeywell thermostat, furnace inop
I replaced a mechanical Coleman Mach thermostat with a Honeywell non-programmable thermostat. I tested out the A/C a few weeks ago and it works fine, even with the toggle switch I added for the fan hi/low setting. When I tried the furnace this weekend, it did not work. The Honeywell displays "heat on" but the furnace does not trigger. I ran the white wire (two wire red and white) to the W position on the thermostat. Where do I start troubleshooting?
  • I made it out to the storage lot this morning and tried setting it on electric but still no luck. The DWM I keep in the TT has a dead battery so my electrical troubleshooting did not happen.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
