Iraqvet05's avatar
Iraqvet05
Installed Honeywell thermostat, furnace inop
I replaced a mechanical Coleman Mach thermostat with a Honeywell non-programmable thermostat. I tested out the A/C a few weeks ago and it works fine, even with the toggle switch I added for the fan hi/low setting. When I tried the furnace this weekend, it did not work. The Honeywell displays "heat on" but the furnace does not trigger. I ran the white wire (two wire red and white) to the W position on the thermostat. Where do I start troubleshooting?
  • Same thing happened to me when I first replaced our stat.
    After much head scratching and tinkering, I realized that I had not set the temp high enough (higher than the ambient temp) to trigger the furnace....:S
    Not saying that this is what is going on with yours...but???
Having RV issues? Connect with others who have been in your shoes.24,238 PostsLatest Activity: Apr 24, 2025
