kmb1966's avatar
kmb1966
Installed new Dometic Rooftop A/C - Do I Dicor caulk?
I just finished installing a new Dometic Brisk Air 2 rooftop a/c unit. Installed it as per the instructions. Nothing is mentioned about caulking around the outside gasket with Dicor or anything. It simply states to tighten the 4 bolts down that squeezes the top a/c gasket to the rooftop. I am supposed to seal around the outside gasket with Dicor or something? Or do you only seal around it if there is a leak? Seems like I would need to seal it additionally with something.
  • Was there sealant on the OLD AC/Gasket? NO. So why would you think it required some type of sealant? Doug
  • I am not sure but if you have a gasket for it you might not need to unless it calls for it in the instructions. If I was going to ad a sealer I would use Sikaflex 715 Roof Sealant.
