dougrainer
Aug 02, 2019Nomad
BFL13 wrote:SidecarFlip wrote:
Try again, your link shows nothing. Photobucket is now a pay site.
Don't break the tube off, it will compromise the weld and may cause a leak. I'd soak the old element and tube with PBlaster to break the bond and remove it.
OK I will try it strapped outside the sleeves.
Sorry, Strapping outside the sleeves will NOT work. You need the weld/inset tube solid contac to transmit the needed BTU's of the Heat Element to the boiler flue. Now, if you can get it beside the old insert sleeves, it may work. Doug
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
