BFL13
Aug 02, 2019Explorer II
dougrainer wrote:BFL13 wrote:SidecarFlip wrote:
Try again, your link shows nothing. Photobucket is now a pay site.
Don't break the tube off, it will compromise the weld and may cause a leak. I'd soak the old element and tube with PBlaster to break the bond and remove it.
OK I will try it strapped outside the sleeves.
Sorry, Strapping outside the sleeves will NOT work. You need the weld/inset tube solid contac to transmit the needed BTU's of the Heat Element to the boiler flue. Now, if you can get it beside the old insert sleeves, it may work. Doug
I have it outside in the long vertical groove between the two sleeves, with a clamp around the whole thing. The back of the element is tight against both sleeves for most of the element's length before it curves at the top I started a cool down on AC and will report how that goes later.
The 325w element as rated, showed 304w at first on the Kill-A-Watt but quickly fell to 286w when the element warmed up, so no issue about using the 325 instead of the specified 300 rating.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
