dougrainer
Aug 12, 2013Nomad
whs9841 wrote:
Doug, thanks for the info regarding the model number....that's good information.
I went back and found all of the documentation I received from my dealer. The model number on my documentation ends with 8564, which would indicate I don't have a hard start capacitor. I found the model number I provided in the original post on the applicances list on the inside of a cabinet door in the 5'er. I'm guessing the model listed on the appliances list in the trailer is incorrect, and the documentation that came with my 5'er is correct. (although you would think the model listed in the cabinet door of the trailer would be more accurate).
I was surprised you had a Jayco Trailer with THAT model number. They usually ONLY install RVP AC units with OEM Hard Start capacitors on Motorhomes, since most motorhomes have a APU. Since starting a Roof AC puts more load/strain on an APU, RVP offers OEM motorhome makers the option of the Hard Start kit. NO, you DO NOT have the Hard Start capacitor. IMO, ALL roof top AC units should have a Hard Start capacitor. As you read here, Most knowledgeable RV'ers install the Hard start kit regardless. It is cheap to do if you do the work yourself. Doug
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
