McKenziek's avatar
McKenziek
Installing a Norcold 1210 in a 2005 Monaco Diplomat
So my 1200LRIM needs replacement and the local RV shop wants $2500 to replace the cooling unit. A new Norcold 1210LRIM is going for $3500 so i'm thinking going with new and installing myself. From what I can see to replace the fridge is pretty straight forward. Disconnect some lines and a few screws. All I want to know is will these units fit through the door opening? Specs say 24" deep but I'm not near my coach to measure the door opening. Can anybody with a similar Monaco measure their door opening? If not > 24" then the front windshield is the only option and I'm not attempting that. All comments appreciated.
  • My 1200 failed but I went the Amish cooling unit route and did it myself with help.
    Not hard and it works better than factory. About $1200 with shipping.
    I agree $1200 is a bit much for labor. Maybe find a mobile guy if you can’t do it or drive it to Elkhart.
    There are videos on YouTube.
  • dougrainer wrote:
    The problem is not the door specs. The problem is, the door is a front door on a Diesel and curved at the top half. You will have to remove the drivers and Pass seat to SAFELY swap them out and prevent damage to the seats. You also have the DASH to worry about. It is best to pull a side LR window. That is what I do. You will also have to disassemble the old refer and the new refer to get the cabinet out and in. We also do that. Disassemble just means removing the 4 doors and hinge brackets. Makes the refer lighter and now will go thru the window cut out. Going out the entry door or window cavity cutout will still require disassembly of the doors and door hinge brackets and the optical board. Doug
    Without actually being there to measure, i'm guessing my side windows are maybe only 16-18" tall but I could be wrong.
  • The problem is not the door specs. The problem is, the door is a front door on a Diesel and curved at the top half. You will have to remove the drivers and Pass seat to SAFELY swap them out and prevent damage to the seats. You also have the DASH to worry about. It is best to pull a side LR window. That is what I do. You will also have to disassemble the old refer and the new refer to get the cabinet out and in. We also do that. Disassemble just means removing the 4 doors and hinge brackets. Makes the refer lighter and now will go thru the window cut out. Going out the entry door or window cavity cutout will still require disassembly of the doors and door hinge brackets and the optical board. Doug
  • I've looked at changing refers in my 2005 Fleetwood Excursion 39S. If I do it, I'll do it through one of the side windows. I've had them out and it's a lot easier than messing with the windshield.
    Bill
  • donn0128 wrote:
    Consider a residential refer for 500 dollars instead. Heck even adding a couple more batteries and an inverter would only cost a few hundred more. Unless you do a lot of dry camping a residental refer would be a better option.
    I've been down the residential fridge option before. Not gonna do it again. We dry camp too much.
  • Consider a residential refer for 500 dollars instead. Heck even adding a couple more batteries and an inverter would only cost a few hundred more. Unless you do a lot of dry camping a residental refer would be a better option.
