Old-Biscuit
Dec 18, 2013Explorer III
Coleman-------------------------Honeywell
RED.............................R (Rc--jumper)
Blue............................Not Used (tape off end)
White...........................W
Green......High A/C Fan Speed
Gray.......Low A/C Fan Speed
Yellow..........................Y
Connect Coleman Green to Honeywell 'G' for Hi Fan
Connect Coleman Gray to Honeywell 'G' for Lo Fan
Install a mini switch Green to one side, Gray to other side......then wire from output side of switch to Honeywell 'G'
Switch J on back needs to be set to HG (not HE)
'B' and/or 'O' on Honeywell not used unless you are wiring for heat pump
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
