Vintage465's avatar
Aug 03, 2018
Installing hubs on EZ-Lube for the first time.......
Has anyone installed a "dry" set of hubs on an EZ-lube axle? And when I say dry, I don't mean with dry bearings. I mean a hub that has freshly greased bearings, new seal, properly tightened with a cotter pin. Since I'm not certain about every aspect of these, I'm not sure about what the hub should be like on the way in. Should I pack the void in the center of the hub with grease? Does it need to be full so when the grease is pumped in from the front of the axle it pushes the grease to the outer bearing? What I've seen online so far isn't real helpful. I'm installing new EZ-lubes axles on my daughters horse trailer. Thinking I need a pile of grease.
Thanks
  • Since your doing it right and packing them by hand, there's no need to fill the void. One voc. tech teacher I knew said the hub would run hotter if you did fill it.
    Otherwise the hub and spindle are no different than those without EZ lubes.
    If you plan on using the EZ's (I wouldn't...) then yes, the center has to be full before grease will travel though to the front bearings. Your right, it takes a ton of grease.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
