rjsurfer
Aug 29, 2015Explorer
Dr Quick wrote:
I have worked a few awnings. First question is which arm did you damage, the front of the rear? If it is the front arm, the "catch mechanism" will hold spring while you replace arm. If it is the rear arm you will need a "vice Grips" to hold shaft when you work on it.
Fist off I used a small 'C' clamp and fastened it to the gutter, then a coat hanger wire to support the end of the shaft so awning will not fall. Pull awning out a few inches for some Wiggle room. If it is the rear arm I think that you will have to set the vice grips so that handle is facing the top of the trailer and resting against trailer, but PLEASE very this first.
There should be a bolt on the end of the attachment that holds awning to the arm. When you take bolt out, hold vice grips to see which way shaft wants to turn. If up that we have it right, if down, insert bolt. Then position vise grips in the down position. Remove bolt then unhook form lower end to take arm out.
To install new arm you may have to "twist" shaft a bit to get top bolt to line up with arm. If shaft needs to be twisted up, you may need a second vice grips so you can take first one off to position to get bolt in.
Great advice, that's sort of what I was thinking and it is the rear arm that needs replacing.
Thanks
Ron
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
