jolooote
Jun 18, 2015Explorer
Hi. You are correct in that you want to disconnect as much as possible when turning the Disconnect switch to the off/Storage position. My MoHo is setup that when in the Storage position & still plugged into 110VAC I still have all 12VDC & AC operations except the battery charge function. This is important in the situation of some camp grounds where the voltage is only about 105 VAC. Being able to shut down the Converter batt. charge function allows the voltage to be a few volts higher and may allow U 2 safely use U'r Air condioner. I won't run my AC on less than 105VAC. This could damage the compressor, and cause failure within a week.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
