DrewE
Oct 23, 2014Explorer III
So long as it's appropriately anchored, reasonably routed, and protected from the elements (with waterproof connectors for any joints, etc.), it should be just fine. Might be best to use a sturdier/thicker cable than would be minimally required going via the interior just for physical protection, or running it in some sort of a tube or bundle if it seems fragile.
I'd probably avoid going on top of the roof unprotected unless I knew the wire was UV rated. There's no real concerns about electrical safety for a video cable, as the voltages and currents involved are miniscule, so pretty much the worse that can happen is that the rear view camera system goes on the fritz.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
